PLM 360 General
Active Contributor
Message 1 of 5 (189 Views)
Accepted Solution
Sequencers - Zero Pad Auto Generated Numbers
189 Views, 4 Replies
10-08-2012 01:25 PM
I am getting errors in my script for my custom auto part numbering.
I am using a script to define a prefix for my part number then select the correct sequencer to use for that prefix family.
That all appears to be working correctly. The error is coming from the libray script SequencOperator. In need to have the next sequence number generated zero padded and if I check the check box on the sequencer I get the following error.
"[sequenceOperator (line 25, col 0)] org.mozilla.javascript.EcmaError: ReferenceError: "padding" is not defined. (sequenceOperator#25)"
Attached is the autonumber script and the definition of the sequencer I am testing. The code is incomplete as not all the possible prefix 'CASE' statements are included as I am currently testing the validity of the script logic.
Any help is appreciated as the script works fine as long as I don't check the zero pad check box on the sequencer
Bob Donovan
Bigge Power Constructors
Product Support
Message 2 of 5 (178 Views)
Re: Sequencers - Zero Pad Auto Generated Numbers
10-08-2012 02:22 PM in reply to: DonovanJr
Hi Bob,
I have also found the same issue, and am looking into it right now.
Joe Piggee
Support Specialist
Product Support
Autodesk, Inc.
Active Contributor
Message 3 of 5 (171 Views)
It seems that the issue is in the sequenceOperator Script...
10-08-2012 03:56 PM in reply to: piggeej
The padding variable of the ZeroFill function is not being passed correctly.
Need a defintion of something line
var padding = SeqGenerator.Length
BD
Active Contributor
Message 4 of 5 (169 Views)
Re: It seems that the issue is in the sequenceOperator Script...
10-08-2012 03:59 PM in reply to: DonovanJr
I added that var statement to the sequenceOperator Script and it is now working correctly.
Not sure if this was an issue with my tenant or all tenants since the sequenceOpertator Script is part of the base tenant.
Any feedback?
BD
Product Support
Message 5 of 5 (160 Views)
10-09-2012 05:46 AM in reply to: DonovanJr
Hi Bob,
We did find this as an issue with all the tenants and will be rolling out an update for everyone.
 Thanks for bringing this to our attention.
Joe Piggee
Support Specialist
Product Support
Autodesk, Inc.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
