PLM 360 General
Message 1 of 3 (79 Views)
Scripting Access to Linked Items
79 Views, 2 Replies
11-22-2012 12:07 PM
Hi I just saw that there was a update for Scripting Access to Linked Items. I wanted to know how to exactly use it. The Wikihelp section only tells you that theres a new object array: itemWorkflowItems, it doesnt really tell you how to use it with an example script.
Can someone provide an example script using this feature?
Message 2 of 3 (72 Views)
Re: Scripting Access to Linked Items
11-22-2012 02:30 PM in reply to: Asingh5
I was able to get it working over the weekend. The following is a bit of the code that I used;
var linked_item = loadItem(item.workflowItems[1].id);
linked_item.ORIENTATION = 'Vertical';
Hope this helps.
David.
Message 3 of 3 (71 Views)
11-22-2012 02:37 PM in reply to: dkeeley
From my testing you can use the new functionality the following way;
item.workflowItems.length                 [Number of linked items]
item.workflowItems                            [Returns entire array]
item.workflowItems[i].id                      [Returns the id of the row number i in the array]
item.workflowItems[i].descriptor
Hope this helps,
David.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
