Some clients on a customer tenant gives a failure on ds.imports.js, and the import view is blank.
Other clients works OK.
Have been checking om permissions, It seems ok
Any surgestion?
Kind Regards
Jesper Brandt
Hello Jesper,
Would it be possible to post your script you are trying to run along with info relating to the import file and workspace you are trying to import to?
I've created a technical support case for this - someone from our team will work with you directly Jesper.
Michelle
