Fusion Manage Forum
Welcome to Autodesk’s Fusion Manage (formerly Fusion 360 Manage) Forum. Share your knowledge, ask questions, and explore popular Fusion Manage topics.
Run Imports script failure
2 REPLIES 2
jpb
308 Views, 2 Replies
Some clients on a customer tenant gives a failure on ds.imports.js, and the import view is blank.
Other clients works OK.
Have been checking om permissions, It seems ok
Any surgestion?
Kind Regards
Jesper Brandt
2 REPLIES 2
jpiggee
in reply to: jpb
Hello Jesper,
Would it be possible to post your script you are trying to run along with info relating to the import file and workspace you are trying to import to?
Joseph Piggee
Fusion 360 Administrator
TPI Composites
jpiggee@tpicomposites.com
michelle.stone
in reply to: jpb
I've created a technical support case for this - someone from our team will work with you directly Jesper.
Michelle
Michelle Stone
Technical Marketing, PDM & PLM
