Solved by obourne. Go to Solution.
OK. I tried this out and followed the instructions to a T and it isn't working for me.
1st I create the action script.
The I creatre the field PAGE_URL as a URL type and add it to my item details.
The I cretea a single line text and past in the computed fiels code. Whne I try to save I get an error message.
I tried and tried and tried and this is not working for me.
Can someone els try out the instructions and see if you get the same problem?
here is a MUCH better URL for instructions:
Glad you found that Orrin! Was going to post the link for you.
I need to update that blog post - use || for the concatenation rather than + and see if that helps.
Michelle
I loks as if the problem has to do with the way the URL is generated. Have a look at the item URL the was created by the script.
