On creating an Item I got the following scriting error:
Since it made no sense to me & didn't appear to point to anything wrong with my script, i decided to try & create the item again. It worked... But its the longest 'scripting' error I've seen so far so I thought I'd share my landmark moment.
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Hi Scott,
Mind posting the script(s) you were using JAVA and computed fields.
item.NUMBER = item.PROJECT.CONTRACT_NUMBER + "-" + item.DECK + "-" + item.AREA;
if (item.AREA <= 9)
{item.WORK_PACK_NUMBER = item.DECK + "0" + item.AREA;}
else
{item.WORK_PACK_NUMBER = item.DECK + item.AREA;}
//=========== sets the related product's Work Allocations ======================//
setLists();
//=========== sets the current Items Number ======================//
item.NUMBER = item.RELATED.CONTRACT_NUMBER + "-" + item.DECK + "-" + item.AREA;
if (item.AREA <= 9)
else
Scott Moyse
setlists:
function setLists(){
var desc = item.descriptor.descriptor;
var tempProduct = null;
if(item.RELATED_TEMP === null){
item.RELATED_TEMP = item.RELATED.descriptor.descriptor;
else if (item.RELATED === null && item.RELATED_TEMP !== null){
tempProduct = new parentObject(item.RELATED_TEMP.descriptor.dmsID);
tempProduct.removeItem(desc);
item.RELATED_TEMP = null;
else if(item.RELATED.descriptor.descriptor !== item.RELATED_TEMP.descriptor.descriptor){
//item.RELATED_TEMP.RELATED_WORK_ALLOCATIONS = removeItem(item.RELATED_TEMP.RELATED_WORK_ALLOCATIONS, item.descriptor.descriptor);
}//end if
if(item.RELATED !== null){
var product = new parentObject(item.RELATED.descriptor.dmsID);
product.addItem(desc);
}//end if
function parentObject(dmsID){
this.myObject = loadItem(dmsID);
this.addItem = function(descriptor){
if(this.itemExists(descriptor) === false){
var currentValues = this.returnItems(descriptor);
currentValues.push(descriptor);
this.myObject.RELATED_ITEMS = currentValues;
this.itemExists = function(descriptor){
if(this.myObject.RELATED_ITEMS === null){return false;}
for (var i = 0; i < this.myObject.RELATED_ITEMS.length; i++) {
if(descriptor === this.myObject.RELATED_ITEMS[i].descriptor.descriptor){
return true;
return false;
this.returnItems = function(){
var currentValues = [];
if(this.myObject.RELATED_ITEMS === null){return currentValues;}
currentValues.push(this.myObject.RELATED_ITEMS[i].descriptor.descriptor);
this.removeItem = function(descriptor){
if(descriptor !== this.myObject.RELATED_ITEMS[i].descriptor.descriptor){
Scott Moyse
There's one computed field in the item details:
BUDGET_HOURS-HOURS_TO_DATE
Scott Moyse
Scott - I just came across pretty much the same error in another tenant. Will report.
And same as you - retrying worked.
Michelle
Scott,
Looks like an issue with stamping userids to the logging section on item creation, checking with the powers to be right now.
sweet 🙂 glad i reported it then
Scott Moyse
