I would like to know if it is possible to send email notification when due day (milestone) is approaching or when it is due? I am hoping there is some type of scripting that I can use for this?
Let me know
Tom
Solved by bastien.mazeran. Go to Solution.
This is currently not possible.
However you could setup notifications based on having tasks assigned to you that are also listed in your outstanding work section.
To achieve this, nagivate to your Profile > Manage Electronic Notifications > and select under workflow E-mail alerts to be notified only when I have an action to perform.
This will generate an automatic email notification for you for all tasks that are listed in your outstanding work. This is the closest you can get at this point in time.
I hope this helps.
