It is always a bit of a problem that when working with a matrix that it always appears over the non-assigned fields box, so that you have to move it to the right. Unfortunately, any change to the matrix and it moves back again. That's the first bugbear I have (though it's relatively minor)!
However, since the April release, I am finding that while I can move the whole matrix window (with the 4 headed arrow), I can no longer resize it as the 2-headed arrow no longer appears on the corners and so you cannot make it bigger (or smaller) accordingly. This is very frustrating, as it increases the time taken editing with having to scroll about the matrix instead and also prevents me from seeing the overview of the whole layout.
Can anyone restore this functionality? If in the process you could also get the matrix window to appear to the right of the non-assigned fields box that would also be wonderful!
Many thanks,
Fiona
Hi Fiona,
The PLM 360 Development Team is aware of this issue and evaluating putting a fix into a future release.
Sorry of the inconvenience.
John
Glad to see the window can now be resized again - thank you.
It does still jump back to its original size and back over the Unassigned fields section of the window, but one improvement at a time is welcome...!
Fiona
