I have an item that displays a field using a 'latest version' picklist (I have attached some images of the set up for clarity). The field is also displayed as a link. When the latest version of the link is revised and released the link text automatically changes to reflect the latest released revision. So far so good. However, the link text and the link hyperlink do not match. In the attached screenshots you can see that although the link text states 'Rev 3' the link actually brings the user to 'Rev 1'.
Any ideas whats going wrong here?
David.
Hi David,
If you move the item to Rev 4, does the link update again correctly? When you choose the link does it still brings you to the item Rev 1 again? Trying to see if the pointer to the correct item continues to not update.
John
David,
You've found a defect that I will forward to the PLM 360 Development Team.
Thank you for pointing this out.
John
Hi John,
This is a pretty serious defect for us. Its going to postpone our implentation project. Can you get me details on a timescale for a fix for this?
David.
