I had a question regarding the import tool. I was trying to import information to a multiple select linking pick list but it wouldn’t let me. I double checked and made sure the values I was trying to add exist.
I took a screenshot of the error I received. Did I enter the data wrong? Or is there something wrong on the PLM side?
Please instruct how to successfully import to a multiple selection pick list.
Hi Amrit,
Thank you for reporting this.
We are aware of an issue with multi-selection import failing with server-side error when the name of the field you are importing to contains a whitespace character. Could you try to create a new field in items and details page with no spaces in its name and repeat the import with multi-selection values again?
Is there a reason why you are not adding to the workspace? Please let me know if you were able to make some progress with this.
Hi Amrit,
I have escalated this issue to a support case and will contact you shortly.
I'm having the same problem. I want to import and update several fields of the item details and if I have a multiple selection picklist, I receive a server side error.
What can I do? I'm not really caring about the multiple picklist right now, but it always gives me a server side error.
Hi Elias,
I will create a new support case for you and send you an email with case number shortly.
