Fusion Manage Forum
Welcome to Autodesk’s Fusion Manage (formerly Fusion 360 Manage) Forum. Share your knowledge, ask questions, and explore popular Fusion Manage topics.
How to Copy and Paste a Workflow
1 REPLY 1
JohnCHill
615 Views, 1 Reply
Do you have a Workflow that you would like to reuse in a new Workspace?
John Hill
Support Specialist
Product Support
Autodesk, Inc.
Tags (3)
1 REPLY 1
JohnCHill
in reply to: JohnCHill
Here is how you can Copy and Paste that Workflow saving you valuable time.
  1. Open the Workflow Editor and load the Workspace to copy from
  2. Use Ctrl A to select all
  3. Use Control C to copy the selection
  4. In the Workflow  Editor, click File and then choose Reload Workspaces
  5. Load the target Workspace with the empty Workflow
  6. Use Ctrl V to paste in the copied Workflow Map
  7. Click File and choose Upload
  8. You can then close the Workflow Editor as there is no need to save changes to the original Workflow Map
John Hill
Support Specialist
Product Support
Autodesk, Inc.
Tags (3)
