PLM 360 General
*Expert Elite*
scottmoyse
Message 1 of 14 (148 Views)
End date is required error
148 Views, 13 Replies
10-04-2012 01:46 PM
I can't add these tasks to my Project Management tab, its telling me I need to add an end date, as you can see there is one. I have been adding tasks to this PM with no issues up until these two.
weird eh!?!?
Cheers
Scott Moyse
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Cheers!
*Expert Elite*
scottmoyse
Message 2 of 14 (146 Views)
Re: End date is required error
10-04-2012 02:02 PM in reply to: scottmoyse
I can't add any tasks which have an end date later than the 12th October!
Cheers
Scott Moyse
Product Support
michelle.stone
Message 3 of 14 (117 Views)
10-04-2012 03:45 PM in reply to: scottmoyse
Scott - can you verify if you have the Default Date Format in the General -> Global Setup Options set to DD/MM/YYYY and not MM/DD/YYYY?
Michelle
Michelle Stone
PLM Product Manager
Autodesk, Inc.
*Expert Elite*
scottmoyse
Message 4 of 14 (112 Views)
10-04-2012 04:23 PM in reply to: michelle.stone
its set to DD/MM/YY:
I can add tasks with dates after the 12th in my SMItemp tenant but not in the SMI one.
Cheers
Scott Moyse
*Expert Elite*
scottmoyse
Message 5 of 14 (110 Views)
10-04-2012 04:30 PM in reply to: scottmoyse
I have also checked the date & time format of my user profile, they are ok & both match in either tenant.
I've also turned off the scripting in the tenant with the error to see if the script generated milestones for those particular dates was causing any problems, but that was the same.
I've wondered if its something to do with 2 weekends being excluded between Start & End date, but turning that option off didn't help either.
Cheers
Scott Moyse
*Expert Elite*
scottmoyse
Message 6 of 14 (104 Views)
10-04-2012 04:47 PM in reply to: scottmoyse
I don't think it is a data formatting issue, because it accepts the 15/09/2012 as an end date.
Cheers
Scott Moyse
*Expert Elite*
scottmoyse
Message 7 of 14 (101 Views)
10-04-2012 04:58 PM in reply to: scottmoyse
My current work around is to add the item to the PM tab with an earlier date, then modify the items milestone afterwards.
Cheers
Scott Moyse
Product Support
michelle.stone
Message 8 of 14 (99 Views)
10-04-2012 04:59 PM in reply to: scottmoyse
Scott - I'm able to recreate and will report.
Michelle Stone
PLM Product Manager
Autodesk, Inc.
Product Support
michelle.stone
Message 9 of 14 (95 Views)
10-04-2012 05:13 PM in reply to: michelle.stone
Scott - turns out it's known issue and being addressed.  Sorry for the inconvenience!
Michelle Stone
PLM Product Manager
Autodesk, Inc.
*Expert Elite*
scottmoyse
Message 10 of 14 (93 Views)
10-04-2012 05:15 PM in reply to: michelle.stone
ok cool, its strange how its ok it works in one tenant but not another. They are both .net tenants as well. Aaaanywho at least you could reproduce it, & I have a workaround, albeit a slightly annoying one.
Cheers for getting onto it Michelle! leeeegend
Cheers
Scott Moyse
You are not logged in.
Announcements
Ask the Community
