Hi again,
I hope I am not missing something really obvious, but I find that once I have navigated away from the main forum page, I find it both hard to get back there and also can see no other way to post a new message. Am I missing something ?
If I am not, then it would be very useful to have the Post Message button elsewhere in the forum and not just at the index/main board page.
If I have been daft, can someone please point out the error of my ways ?
Thanks!
Fiona
Solved by JohnCHill. Go to Solution.
You can best navigate the forum by using the Back button on your browser or using the bread crumbs located below the main menu of the Autodesk PLM 360 forum.
Agreed, but neither is optimal when you want to post a new message. The back button may take several clicks to get back to where you can post a message, depending what path you have gone down.
The breadcrumbs often only give the option to skip back to the list of all Autodesk forums and from there you then have to go back to PLM360 before you can post. This happens for example when you have run a search. The breadcrumbs there are then just:
I gues it's because the search searches all discussions not just PLM360, so then it wouldn't know where you wanted to post the message.
Not major, but it is mildly irritating! Still, I'd rather the developers spent time on getting the new release BOM & Grid functionality ready to go in PLM360 than spent time on this!
Cheers,
Fiona
My Hagerman suppport has left me hanging on creating a fly-through of a hallway I created in Inventor 2014. I have a question that they can not answer. How do I post a question here?
Hi Randy,
This forum is for PLM 360 only. If you have Inventor related questions, please go to the Inventor forums:
http://forums.autodesk.com/t5/Autodesk-Inventor/bd-p/78
Once there, simply click on New Message button at top left corner of the page to submit a new question.
