Fusion Manage Forum
Welcome to Autodesk’s Fusion Manage (formerly Fusion 360 Manage) Forum. Share your knowledge, ask questions, and explore popular Fusion Manage topics.
Derived field updating
9 REPLIES 9
Message 1 of 10
dkeeley
644 Views, 9 Replies
A quick question. I have an item that has a field that derives its value from a field in another workspace. The derived field populates correctly when I select a new item from the linked pick list. So far so good. However, when the value of the field in the original item is changed - it does not automatically update in items where the value of the field is displayed as a derived value. Is this normal behavior?
Thanks for your help,
David.
Tags (1)
9 REPLIES 9
Message 2 of 10
dkeeley
in reply to: dkeeley
OK,
So I checked the Help and according to this I shouldn't be seeing what I am seeing. Am I missing something? Is there a time lag between the field in the parent item being updated and these changes being reflected in derived fields?
http://wikihelp.autodesk.com/PLM_360/enu/Help/Help/0040-Administ40/0049-Setup49/0050-Workspac50/0053...
David.
Message 3 of 10
dkeeley
Some images attached.
Message 4 of 10
JohnCHill
Hi David,
If you have a record open and make a change to a Derived Field Source you do need to refresh the record page to see that change.   I've seen the field automatically update after editing a record or refreshing the page.
John Hill
John Hill
Support Specialist
Product Support
Message 5 of 10
dkeeley
in reply to: JohnCHill
Hi John,
Thanks for the message.
However, I've already tried refreshing, logging out and back in, and leaving overnight - its still not updating.
David.
Message 6 of 10
JohnCHill
I've tested and I cannot recreate this issue with the Derived Field.  Can you try deleteing and recreating the Derived Field in the workspace?   Also send me a screen shot of the Test field configuration.
Thank you.
John
John Hill
Support Specialist
Product Support
Message 7 of 10
dkeeley
Hi John,
Can I give you a log on to our tennant? If so please email me and I will send you the details.
David.
Message 8 of 10
JohnCHill
David,
I can duplicate this issue using the BOM Picklist as the pivot field.
I will esculate this issue to the PLM 360 Development Team.
Thank you for bringing this to my attention.
John
John Hill
Support Specialist
Product Support
Message 9 of 10
dkeeley
Thanks John. How long do you think it will take to rectify?
Message 10 of 10
JohnCHill
This issue will be prioritized by the Development Team and fixed in a future update to PLM 360.  Since the issue was just esculated it is hard to say at this point when a fix will be in place.
John
John Hill
Support Specialist
Product Support
