PLM 360 General
dkeeley
Message 1 of 10 (275 Views)
Derived Fields on Import
275 Views, 9 Replies
10-10-2012 02:14 AM
I am running an import where I am importing a value that matches one on a workspace-linked pick list. This seems to import OK. However, the item also has some derived fields from the pick list selection. These do not seem to resolve on import. The only way they seem to resolve is when I create a new item manually or when I edit the item I have imported. Has anyone got any ideas on this?
David.
Product Support
piggeej
Message 2 of 10 (263 Views)
Re: Derived Fields on Import
10-10-2012 07:15 AM in reply to: dkeeley
Hi David,
Nice catch! This is a bug and is now reported.
Joe Piggee
Support Specialist
Product Support
dkeeley
Message 3 of 10 (259 Views)
10-10-2012 07:29 AM in reply to: piggeej
Hi Joe,
Thanks for the reply. How long would you expect it to take to correct this? hours, weeks, months?
No pressure ;-)
David.
dkeeley
Message 4 of 10 (252 Views)
10-10-2012 03:08 PM in reply to: dkeeley
Hi Joe,
I also seem to have the same problem when importing to a workspace with filtered picklist fields. The 'non-filtered' pick-list fields seem to import OK. But when I try to import into a filtered field I get an error messge. I have attached an image of the error message at import.
David.
dkeeley
Message 5 of 10 (251 Views)
10-10-2012 03:09 PM in reply to: dkeeley
One more image for the above post.
dkeeley
Message 6 of 10 (202 Views)
03-01-2013 05:49 AM in reply to: dkeeley
Hi. Any update on this? We are at the data import stage of our implementation project and this issue is still causing problems.
David.
Product Support
piggeej
Message 7 of 10 (196 Views)
03-01-2013 07:38 AM in reply to: dkeeley
Hi David,
I haven’t heard anything yet, but I did ask the Devs for an update. I will let you know as soon as I hear something
Joe Piggee
Support Specialist
Product Support
Valued Contributor
j.hendrickson
Message 8 of 10 (147 Views)
12-03-2013 10:49 AM in reply to: piggeej
Has there been any progress on this?  I seem to be running into exactly the same problem as the OP.  In addition, OnEdit scripts don't run after doing an import, possibly related?
Thanks.
Active Contributor
sten
Message 9 of 10 (108 Views)
02-14-2014 03:03 PM in reply to: j.hendrickson
I guess this problem has been here for a long time.
I am also trying to import into a workspace with derived fields, and right now I have to manually go into each one of the to force an update.
Is there any workaround for this.
I don't really want to waste hours on this.
Sten
New Member
JAU007
Message 10 of 10 (76 Views)
05-02-2014 04:23 AM in reply to: dkeeley
I'm also struggling with this same issue. When I update a pick-list field value by excel-file import, the derived fields from the pick-list don't get updated. This is a problem when handling large amounts of data so hopefully there will be a solution soon.
Johan
You are not logged in.
Ask the Community
