Fusion Manage Forum
Welcome to Autodesk’s Fusion Manage (formerly Fusion 360 Manage) Forum. Share your knowledge, ask questions, and explore popular Fusion Manage topics.
Derived Fields on Import
10 REPLIES 10
Message 1 of 11
dkeeley
664 Views, 10 Replies
I am running an import where I am importing a value that matches one on a workspace-linked pick list. This seems to import OK. However, the item also has some derived fields from the pick list selection. These do not seem to resolve on import. The only way they seem to resolve is when I create a new item manually or when I edit the item I have imported. Has anyone got any ideas on this?
David.
10 REPLIES 10
Message 2 of 11
jpiggee
in reply to: dkeeley
Hi David,
Nice catch! This is a bug and is now reported.
Joseph Piggee
Fusion 360 Administrator
TPI Composites
jpiggee@tpicomposites.com
Message 3 of 11
dkeeley
in reply to: jpiggee
Hi Joe,
Thanks for the reply. How long would you expect it to take to correct this? hours, weeks, months?
No pressure 😉
David.
Message 4 of 11
dkeeley
Hi Joe,
I also seem to have the same problem when importing to a workspace with filtered picklist fields. The 'non-filtered' pick-list fields seem to import OK. But when I try to import into a filtered field I get an error messge. I have attached an image of the error message at import.
David.
Message 5 of 11
dkeeley
One more image for the above post.
Message 6 of 11
dkeeley
Hi. Any update on this? We are at the data import stage of our implementation project and this issue is still causing problems.
David.
Message 7 of 11
jpiggee
Hi David,
I haven’t heard anything yet, but I did ask the Devs for an update. I will let you know as soon as I hear something
Joseph Piggee
TPI Composites
Message 8 of 11
Has there been any progress on this?  I seem to be running into exactly the same problem as the OP.  In addition, OnEdit scripts don't run after doing an import, possibly related?
Thanks.
Message 9 of 11
sten
I guess this problem has been here for a long time.
I am also trying to import into a workspace with derived fields, and right now I have to manually go into each one of the to force an update.
Is there any workaround for this.
I don't really want to waste hours on this.
Sten
Message 10 of 11
JAU007
I'm also struggling with this same issue. When I update a pick-list field value by excel-file import, the derived fields from the pick-list don't get updated. This is a problem when handling large amounts of data so hopefully there will be a solution soon.
Johan
Message 11 of 11
So I'm running into this issue again, almost exactly a year later.  Any updates on whether we'll get support for filling in derived fields after importing?  I'm working on a workaround with filtered pick lists in the meantime, but that has its own problems.
I'll add this to Idea Station too but I figured I'd respond to this thread since it's still sitting out here waiting for some TLC.
Joe Hendrickson
