Is there a way to delete an item via script? For example as an action script that will run when a transition occur
Elias,
This should help you out...
item.deleteItem()
Deletes the item associated with the script. See also descriptor.deleted.
Descriptor Properties on the item Object
Descriptor properties on the item object (item.descriptor) represent item metadata.
