PLM 360 General
Product Support
JohnCHill
Message 1 of 5 (190 Views)
Default entry if no information is entered into a specific field
190 Views, 4 Replies
06-14-2012 06:02 AM
How do you ensure that there is a default entry if no information is entered into a specific field?
John Hill
Support Specialist
Product Support
Product Support
JohnCHill
Message 2 of 5 (189 Views)
Re: Default entry if no information is entered into a specific field?
06-14-2012 06:02 AM in reply to: JohnCHill
Use the” Default Value” within the configuration of the field and enter the value you would like if no text is entered when creating a record.
John Hill
Support Specialist
Product Support
Valued Contributor
fhmurray
Message 3 of 5 (135 Views)
09-27-2013 03:47 AM in reply to: JohnCHill
I have set up default entries for various fields in different workspaces.  However, I am then using the Import facility to add new records and when I go to these uploaded records, the fields that should have default values are either blank (in terms of the Float fields) or still say ---Select--- in the case of picklist ones.
Is this right ?  It seems illogical and will be very time consuming to have to input the values later.  All I can think is that the initial upload will have to have the default value of 0.00 in the applicable fields - also time-consuming to do.
Would very much like clarity on this to understand how to manage this if it is indeed the case for uploaded records.
The default values do not appear after editing the record either.
Fiona
Product Support
JohnCHill
Message 4 of 5 (113 Views)
10-02-2013 01:19 PM in reply to: fhmurray
Hi Fiona,
When you import you’re bypassing the settings for that specific field even if it has a default value. The only exception to this rule is a computed field.
You would indeed need to enter the value for the field in the import
John Hill
Support Specialist
Product Support
Valued Contributor
fhmurray
Message 5 of 5 (101 Views)
10-07-2013 08:10 AM in reply to: JohnCHill
Thanks for clarifying, John.
You are not logged in.
Ask the Community
