I have a date field in a grid that doesn't let the user enter or select a date at the time they add the line. Once it's been added you can edit the line and select a date. Is that how it's suppose to work? There's no scripting associated with the date field.
Hi James,
You should be able to select the specific date from a Date Field when you add a Row to the Grid. I have been able to duplicate this behavior and will let the PLM 360 Development Team know that this feature is not working properly.
Thank you for pointing this out.
John
