Is there a way to customize the layout of the Item Details tab? Currently I see the fields stacked top to bottom. I want to be able to arrange the field display as a form and input data that way. This would be a parallel to enetring in data on a PDF document.
The attached file shows a document I cutrrently use. I'd like to migrate this to 360 but keep the current layout.
When you are building the Item Details Fields for your workspace try using a Matrix. With the Matrix you can move fields from left to right on the Item Details tab and I have created multiple workspaces based on a PDF document.
Hope this helps,
John
I checked it out. It's OK. I would prefer full on customization but can probably make it work as is.
Thanks for the tip.
