PLM 360 General
Member
Rdisplay
Message 1 of 9 (250 Views)
Custom Part Numbering Schema
250 Views, 8 Replies
04-13-2012 07:49 AM
Hello, I am trying to setup a part numbering schema that follows our practice. The samples that are included do not match what I need, and I cannot seem to find where to get this setup in the system. Thank you. Cordially, Arno
Product Support
piggeej
Message 2 of 9 (246 Views)
Re: Custom Part Numbering Schema
04-13-2012 08:01 AM in reply to: Rdisplay
Arno,
To better tailor an answer for you that will meet your needs, can you please provided an example of what you would like this number to look like, also are you trying to use to auto-number field  or tailor the Sequencer workspace to achieve this?
Joe Piggee
Support Specialist
Product Support
Member
Rdisplay
Message 3 of 9 (242 Views)
04-13-2012 08:15 AM in reply to: piggeej
Joe, Thank you for the reply. My part numbers are as follow: Part numbers are 8 alphanumeric digits with a dash between the first 4 letters and last 4 numbers: A BCD-1234 First letter designates the product from a high-level view, for example: Component Documentation Assembly (anything with a multi-parts BOM is an assembly, for the most part) Finished Product (anything with a barcode) Second letter designates a category: Last two letters designate the detail of the second letter designation. Numbers are sequential, but I may want to use specific ones in some instances where it makes sense. Thank you. Cordially, Arno
Member
Rdisplay
Message 4 of 9 (241 Views)
04-13-2012 08:16 AM in reply to: Rdisplay
How do you put line carriage returns in here? My posts show up without the CR, and everything is in one big paragraph. Annoying... Thank you. Arno
Product Support
piggeej
Message 5 of 9 (232 Views)
04-13-2012 10:57 AM in reply to: Rdisplay
Arno,
In this scenario are you pulling items from multiple ‘item workspaces’ or are they all grouped in a single workspace?
Joe Piggee
Support Specialist
Product Support
Product Support
piggeej
Message 6 of 9 (225 Views)
04-13-2012 11:50 AM in reply to: piggeej
Arno,
If you are using a single item workspace, you would be able to generate this item with the combination of the “Sequencers workspace” and Modification of the ItemSeqGen action script.
However your lastline  (currently line 14) would look something like:
Item.Number = highview + catNumber + subview ‘-‘ + newItemNumber;
Key:
high-level view (1) - hlview
category (1) - catNumber
detail of the second letter(2) -subview
Numbers are sequential (4) - newItemNumber
Joe Piggee
Support Specialist
Product Support
Member
Rdisplay
Message 7 of 9 (202 Views)
04-16-2012 01:39 PM in reply to: piggeej
Thank you for the answer. I haven't gone into the scripting yet, but this seems quite a bit complicated... Is there any tutorial in particular that refers to this? Thank you. Cordially, Arno
BorisChan
Message 8 of 9 (197 Views)
04-16-2012 02:59 PM in reply to: Rdisplay
Hi Arno,
Joe is traveling today.
Michelle Stone has posted a similar response to scripting in the post titled: server side JavaScript.
I am re-posting her response here as FYI:
All the currently available information about scripting is on our WikiHelp in the scripting section.  As new information becomes available, you'll find it there.
Boris Chan
Product Support Specialist
Product Support
piggeej
Message 9 of 9 (147 Views)
05-03-2012 12:55 PM in reply to: Rdisplay
Arno,
I had a request for this on Tuesday so I thought I would share it with you. This is a simple case senerio based on single workspace auto numbering based on conditions chosen:
Purpose:
Create a custom part number based on options selected in the workspace
var a = item.PRE_CONDITION; //sets pre number based on item chosen
var b = item.AUTO_NUMBER; //brings in the number provided by the auto numbering field
var c = item.POST_CONDITION; //sets post number based on variable chosen
var d = '00-0000-00'
//selection for pre number
switch (a)
case "wood":
var a = 01
break;
case "plastic":
var a = 02
break;
case "metal":
var a = 03
//selection for post number
switch (c)
case "alpha":
var c = '99'
break;
case "beta":
var c = '88'
break;
case "omega":
var c = '77'
var d = a+'-'+b+'-'+c; //create the number layout
item.PART_NUMBER = d; //add it back to the workspace
Joe Piggee
Support Specialist
Product Support
You are not logged in.
Ask the Community
