Fusion Manage Forum
Welcome to Autodesk’s Fusion Manage (formerly Fusion 360 Manage) Forum. Share your knowledge, ask questions, and explore popular Fusion Manage topics.
Conditional visibility of field
12 REPLIES 12
Message 1 of 13
946 Views, 12 Replies
Hi, I would like the visibility of a data entry field in the item details tab to be conditional on the value of another field (such as a checkbox).  I see conditional validations that are dependent on another field, but would like to be able to completely hide a field unless a condition is met.  This would help make the data entry requirements clearer to the user during item creation/editing, rather than getting an error message after clicking "save".  Is this functionality currently available?  If not, I can submit to IdeaStation.  Thanks!
12 REPLIES 12
Message 2 of 13
bastien.mazeran
This feature you are looking for is currently not available. Please submit this feature request to the PLM 360 Idea Station.
What you can however do at this time is to return some feedback to user when checkbox is selected. The field that depends on the checkbox field could become a computed field that checks whether checkbox is selected or not and displays some text accordingly.
The computed field syntax would be similar to this provided the checkbox item is called CHECKBOX.
CASE
WHEN (CAST(CHECKBOX as FLOAT) = 1)
  THEN 'The check box is selected'
ELSE
   'The check box is not selected'
END
Bastien Mazeran
Technical Support Specialist
Message 3 of 13
in reply to: bastien.mazeran
Thanks, is it possible to use the computed field to make the text a
different color depending on the "CASE"?
*-Ty*
Message 4 of 13
bastien.mazeran
Hi Ty,
Yes. You can leverage HTML <span></span> element in your computed field to change the text color, font style and weight.
Please refer to this URL for further details:
http://wikihelp.autodesk.com/PLM_360/enu/Community/Tips/Configuring_Fields/Computed_Fields%3a_Small_...
Bastien Mazeran
Message 5 of 13
Thanks, that is good stuff.  I was able to make red, bold, italic text using the following:
 '<span style="color:red; text-transform:uppercase;font-style:italic;font-weight:bold;">MUST MAKE CATEGORY SELECTION</span>'
However, I'm trying to do a mashup of HTML with a CASE structure and not having any luck.
Here is my "code".
The "CATEGORY" field is a pick list.  The intent is for the computed field text to be green if a selection has been made in the CATEGORY field.   If a CATEGORY has not been selected, then the red warning text should appear.
With the above code, my text is simply returning the default, currently set to "test".  Any suggestions on the code, or am I bumping up against a code limitation?
Message 6 of 13
bastien.mazeran
Ty,
Could you please try with this WHEN statement?
WHEN (CAST(CATEGORY as Float) = -999)
My testing indicates that when nothing is selected in the picklist, the category float value is equal to -999.
Bastien Mazeran
Message 7 of 13
Tried, but suggestion did not work. Also tried removing the HTML, still
did not work.
CASE
WHEN (CAST(CATEGORY as FLOAT) = -999)
THEN 'MUST MAKE CATEGORY SELECTION'
ELSE
'Category Selected'
END
Message 8 of 13
I was able to get the HTML work (without the CASE structure), but only during cloning.  I don't want the computed filed to be visible when viewing items, so I have the field visibility set for "edit" only.  However, it does not show during creation, only editing or cloning an existing record.  Shouldn't this also work during creation?
Message 9 of 13
bastien.mazeran
Hi Ty,
Maybe the null selection in your picklist does not return -999 in your case. To determine the value here is what I used in my computed field:
CASE
WHEN (CAST(CATEGORY as Float) > 0)
THEN CATEGORY
ELSE
CATEGORY
END
This returns the float value associated with the selection you made in your picklist.
Bastien Mazeran
Message 10 of 13
I suspect that the computed field does not compute until the item is created, therefore I cannot get the behavior I want (HTML) during Item creation.   Is that correct?
Message 11 of 13
bastien.mazeran
Hi Ty,
Computed fields are only "computed" when you save the item.
Bastien Mazeran
Message 12 of 13
I am trying to use computed fields to display a message to the end user, when a particular field is blank after save.
I am trying below code:
CASE
    WHEN APPROVER IS null THEN 'tEST'
    ELSE 'TEST 2 '
END
but i can't get the message to display on save, and didn't get any error.
Thanks!
Message 13 of 13
bastien.mazeran
Hello Harish,
This is working fine for me. I could edit / save and see the value in the computed field or simply refresh the page. Have you checked if you have scripts that write to the computed field by mistake? I would also ask that you double check the field ID value of the approver field.
Thank you,
Bastien Mazeran
