Fusion Manage Forum
Welcome to Autodesk’s Fusion Manage (formerly Fusion 360 Manage) Forum. Share your knowledge, ask questions, and explore popular Fusion Manage topics.
Computed Field Syntax
2 REPLIES 2
dkeeley
646 Views, 2 Replies
I previosuly used SQLT on computed fields. This now longer appears to work. I believe the new syntax is PosdtgreSQL. Can you tell me how I can extract the week from a date in a computed field? Also how can I display today's date. I can displat the timestanp using 'now()' but I can't figure out how to extract just the date portion.
Thanks for you help,
David.
2 REPLIES 2
Andrew.Shaw
in reply to: dkeeley
Hello David,
You can extract the day as a string by using the following formula: to_char(FIELD_NAME,'dd').
However, if the target data type is numerical, use the following formula: to_number(to_char(FIELD_NAME,'dd'),'99').
Best regards,
Andrew Shaw
Premium Support Specialist PLM/PDM
Global Services
Autodesk, Inc.
dkeeley
in reply to: Andrew.Shaw
Thanks Andrew! Perfect.
