Can I compare multiple baselines within the project management tab and further export the data?
You can compare a baseline to the current schedule but not two baselines together - to compare you select any named baseline from the drop down:
the results will look like this:
There isn't anyway to export the data
Thank you for the reply, I did know how to do that, but was hoping to be able to compare the base lines over the entire course of the program, and having an exprt function could help that
