PLM 360 General
Message 1 of 2 (57 Views)
Changing info in a derived field
57 Views, 1 Replies
10-02-2012 07:18 PM
I am trying to create an ECO number field that would populate from the ECR number but with a "ECO" prefix on the front of the ECO number.
I feel a derived field would be a fit but not seeing how the picklist would fit.
Any ideas or different directions I can try?
Thanks!
Product Support
Message 2 of 2 (43 Views)
Re: Changing info in a derived field
10-03-2012 07:38 AM in reply to: stapprich
Simon,
(Sorry about moving your post but wanted to make it easier for others to see this info)
Unfortunately, derived fields are one way mirrors. You cannot edit the information in a derived field. However, you could use it to transfer information and then script to rebuild the information i.e. ECO to ECR, but this would be way more complex then needed.
The best solution for this would be to have a single select field for ECO or ECR, with a separate filed for the number. Then what you could do is use the derived field for the number only and allow the Item descriptor to combine field 1 and field 2 for you with would in turn give you a ECO or ECR number for the item in question.
This should help you achieve the desired effect for what you’re looking for.
Joe Piggee
Support Specialist
Product Support
Autodesk, Inc.
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
