PLM 360 General
*Expert Elite*
scottmoyse
Message 1 of 11 (259 Views)
Accepted Solution
Change user status to Deleted
259 Views, 10 Replies
05-09-2012 04:17 PM
If you change the status of a user to Deleted, is it treated the same way as an Item Record which is 'Deleted'
If so whats the difference between Inactive and Deleted? is it just a licensing thing?
Cheers
Scott Moyse
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Cheers!
BorisChan
Message 2 of 11 (257 Views)
Re: Change user status to Deleted
05-09-2012 05:03 PM in reply to: scottmoyse
I did a test in QA by setting a test user to "deleted" and the user will be shown with "Deleted" status highlighted in Red in the user setup screen.
The test user is initially assigned as approver in one change order. After the deletion, the user is no longer visible as an approver on the change order. However, I woud not say this is the desired outcome.
Hope others can chime in and advise..
Boris
Product Support Specialist
Global Services
*Expert Elite*
scottmoyse
Message 3 of 11 (256 Views)
05-09-2012 05:10 PM in reply to: BorisChan
but if you chose Inactive it would still appear in the CO?
Cheers
Scott Moyse
BorisChan
Message 4 of 11 (250 Views)
05-09-2012 07:03 PM in reply to: scottmoyse
I tested again. Inactivating an user has similar behavior as deleting user on the CO.
Boris
*Expert Elite*
scottmoyse
Message 5 of 11 (245 Views)
05-09-2012 07:16 PM in reply to: BorisChan
Ok, so I wonder what the difference is then
Cheers
Scott Moyse
Employee
jared.sund
Message 6 of 11 (236 Views)
05-10-2012 02:53 PM in reply to: scottmoyse
Scott,
Functionally there is no difference between Deleted and Inactive user states.  The two different labels are just available for the administrator to classifiy the two differnt types of users.
-Jared
Jared Sund
Sr. Product Line Manager, Product Lifecycle Management
Autodesk, Inc.
*Expert Elite*
scottmoyse
Message 7 of 11 (234 Views)
05-10-2012 03:01 PM in reply to: jared.sund
Cheers Jared
Cheers
Scott Moyse
Distinguished Contributor
AEC_Cadd
Message 8 of 11 (135 Views)
09-14-2012 09:23 AM in reply to: scottmoyse
Where or how do you change the status of a user to deleted?
Product Support
michelle.stone
Message 9 of 11 (129 Views)
09-14-2012 12:31 PM in reply to: AEC_Cadd
Check out the Wiki for help on user administration.
Hope that helps!
Michelle
Michelle Stone
PLM Product Manager
Autodesk, Inc.
AEC_Cadd
Message 10 of 11 (123 Views)
09-17-2012 09:00 AM in reply to: michelle.stone
I'll try to be a bit more spacific. Where do I find the Users tab? How do I get started? Is this a separate program? Is this part of AutoDesk or a separate piece of software?
Thanks in advance for your help.
You are not logged in.
Announcements
Ask the Community
