PLM 360 General
Message 11 of 16 (93 Views)
Re: Change Milestone State using scripting
01-08-2013 06:49 AM in reply to: piggeej
Joe,
Thanks for the feedback. I'm still a little confused. The WikiHelp suggests that this functionality should be available. The following is stated in the scripting reference page (link below). Have I misunderstood?
Methods on the Milestones Array
milestones.setWorkflowState("SHORT_NAME")
Method to set the workflow state associated with the milestone (milestones.workflowState). The "SHORT_NAME" parameter takes the value for the milestones.workflowState.shortName property.
Is this only available at milestone creation? If so then this clears things up.
Product Support
Message 12 of 16 (87 Views)
01-08-2013 12:52 PM in reply to: dkeeley
David,
This is available for creation or modification. Not for deletion or renaming.
Joe Piggee
Support Specialist
Product Support
Message 13 of 16 (84 Views)
01-08-2013 01:36 PM in reply to: piggeej
Hi Joe,
Thanks for the reply.
I just want tp be crystal clear about this incase I've misunderstood something;
A milestone has the following properties;
1 Workflow State
2 Milestone event
3 Target Date
4 Status
5 Warning Days before
6 Workflow progress
So if I understand you correctly the following statements are correct??
a> Properties 1 to 6 can be set on creation via a script.
b> Properties 2 to 6 can be edited via a script. Property 1 cannot.
c> A milestone cannot be deleted via scripting.
Product Support
Message 14 of 16 (80 Views)
01-09-2013 05:28 AM in reply to: dkeeley
David,
Correct!
Joe Piggee
Support Specialist
Product Support
Message 15 of 16 (75 Views)
01-10-2013 06:12 AM in reply to: piggeej
Thanks for the help Joe (and your patience :smileyhappy:).
Great service.
Product Support
Message 16 of 16 (72 Views)
01-10-2013 06:31 AM in reply to: dkeeley
Glad I could help out :smileyhappy:
Joe Piggee
Support Specialist
Product Support
You are not logged in.
Ask the Community
