I have a pick list field with all users as the selection list called "TASK_ASSIGNED_TO"
I use item.master.additionalOwners.push(item.TASK_ASSIGNED_TO); and I get an error.
What am I doing wrong?
Yes I thought that might be the case, I also tried
var user = item.TASK_ASSIGNED_TO;
var usr = Security.loadUser(user);
item.master.additionalOwners.push(usr)
without any luck, the output of this is all null
some help would be apreciated
I also could not see the library script you refer to
thanks again
James - right now there isn't a way to get the user object from the picklist. To add additional owners the record needs to be updated manually, but it's a known issue and being worked to allow this through scripting.
(and OT, but your Advanced Print View stuff will be looked at soon! Saw the case come in and someone will look at it this week).
Michelle
