PLM 360 General
Active Member
james.n.tennent
Message 1 of 3 (119 Views)
Add relationship after creating item
119 Views, 2 Replies
04-14-2013 10:05 PM
Hi Again,
I seem to be finding all the bugs at the moment, although I hope I am wrong.
It doesn't look like I am able to create a new item through a script and Add It to the relationships tab at the same time
(Using the createNewItem library of course)
if(item.CREATE_CHANGE_ORDER === "Yes"){
var newProperties = [];
newProperties.LINKED_CAPA = item.descriptor.descriptor;
createNewItem('WS_UPGRADE', newProperties);
item.ASSOCIATED_CHANGE_ORDER = newItem;
item.relationships.addRelated(item.ASSOCIATED_CHANGE_ORDER,'Cross-Reference','Bidirectional','Link Change Order to CAPA');
each segment of the script works fine by itself however doesn't work together, my thought where I need to Add a delay to the item.relationship section however this didn't seem to help.
thanks again
James
Member
sarychev
Message 2 of 3 (100 Views)
Re: Add relationship after creating item
04-15-2013 10:40 AM in reply to: james.n.tennent
Hi JamesI too try decide this issue...
You get error (java.lang.RuntimeException: Unable to save script results) ?
P.S. Maybe this features not supported, like a "scrypting-based" change owner (before last update) ?
dkeeley
Message 3 of 3 (89 Views)
04-17-2013 01:46 AM in reply to: james.n.tennent
Hi James,
Maybe this would work?
var newItem = createNewItem('WS_UPGRADE', newProperties);
David.
You are not logged in.
Announcements
Ask the Community
