I would like to be able to access the comments on the workflow transition to include in an email notification via scripting. Is this data accessible via scripting?
item.workflowActions[i].comments should allow access to comments placed on a workflow action.
Thanks Eric, so does 'i' represent the workflow action step that you want the comment from?
I’m trying to access the workflow comments in a script that fires on the transition to send an email. I want to put these comments into the email. I have the code to access the comments item.workflowActions[i].comments (thanks Eric) and can get the comments, however it appears that the script fires before the comments are “saved” to this location. If I hard code in the action step I can use the comments from the previous transition but if I try to send comments from the current transition I get a blank/null result. Any ideas?
Has been working fine for me for a little over a year. I have a process that emails out the last transitions comment. Has worked every time for me.
Can you share your script?
I am attempting to do the same thing. I can only access the comments if i hard code the transition step. Can you share your script?
Not sure if this is what you're looking for, but array element 0 (zero) is that last transition. It's always zero which is pretty helpful. So you'd want to check if the comment is populated and if that's true then do some cool stuff. 🙂
if (item.workflowActions[0].comments) { // Do cool stuff }
If comments is populated then it results in true and does cool stuff.
If you need to get a specific comment from a specific workflow transition, it's possible but takes a few more lines of code to step through the workflowActions and test the comment against a string value or with a regex expression. Totally doable though.
