Welcome to our PLM 360 Community!
The information you are looking for regarding accessing specific item fields can be found in our WikiHelp.
http://wikihelp.autodesk.com/PLM_360/enu/Help/Help/0032-Administ32/0059-Scriptin59/0060-Scriptin60
In particular, look at the section for 'The "item" Object and Access to Item Fields'.
Hope that helps.
Michelle
Hi Michelle,
Thanks for the response and the welcome.
This actually isn't quite what I'm looking for. I'm not looking to access this data via scripting within the PLM, but rather from external scripts within other systems over the REST Api (located at {base_url}/api/rest/application.wadl). Do you know if this is possible? I need to pull our data out of the PLM and push it into our own systems once a certain point in the workflow is reached.
Thanks for your time,
Jamie
Hi Jamie. API services will be introduced in a later release - stay tuned.
When we make the web services available for use, we will have the documentation / release notes available on our website. (http://wikihelp.autodesk.com/PLM_360/enu/Help).
Michelle
Thanks for the quick response.
Do you know when or at least a rough idea of when the API's will be officially released? Also do you know if the level of details I'm looking for will be part of the API when it is released?
I'm working on a very agressive time frame w/ my company and a lot of it will depend on having access to this data.
Thanks again,
~Jamie
Hi Jamie,
I send you a direct message so I can understand a little more about what you want to do. Thanks!
