Fusion Manage Forum
Welcome to Autodesk’s Fusion Manage (formerly Fusion 360 Manage) Forum. Share your knowledge, ask questions, and explore popular Fusion Manage topics.
system date
5 REPLIES 5
636 Views, 5 Replies
system date
How do I change the systemdate printed in the advanced print view footer?
${system.printDate}
I want the date to correspond with the actual time.
Kind regards,
Jonas
5 REPLIES 5
JohnCHill
Hi Jonas,
When you create your Advanced Print View you need to insert the Header/Footer first.
Click on the “Gear” in the Advanced Print View menu.  Use the drop down to choose Header Footer and then below highlight “Insert content here” and then choose what data you want between the Header and footer.  Once you save your Advanced Print View and print it from the record you will see the date and time at the bottom.
John
John Hill
Support Specialist
Product Support
Autodesk, Inc.
in reply to: JohnCHill
Hi John,
that is what I did. However, the time is a few hours off. I need to change the "systemDate" somehow for it to be my current time zone.
Kind regards,
Jonas
jpiggee
Hi Jonas,
John asked me to have a look at this,
When in the advanced Print view open up the HTML editor and add this code.
This code will add the Header/Footer to the print view and modify the Time section to display the local time of the computer printing the item.
::start of code::
<div class="headerFooter">
<table class="headerFooter">
<thead>
<tr>
<td>
<div class="print_header">
<div id="print_header" class="itemDescriptorWrapper">
<div id="itemdetails " class="workspacerow">
<div class="itemdescriptor">
<h2>${workspace.metadata.headerFooter.imageHeader.value} ${workspace.metadata.itemDescriptor.itemDescriptor.value} <span style="color: red;">${workspace.metadata.itemDescriptor.itemDeleted.value}</span></h2>
<!--#if(${workspace.metadata.itemDescriptor.workingVersion.value} != "")--> <span class="open-change-indicator"> ${workspace.metadata.itemDescriptor.workingVersion.value} </span> <!--#end--></div>
<!--#if(${workspace.metadata.lifecycle.lifecycle.value} != "")--><hr /><!--#end--><!--#if(${workspace.metadata.lifecycle.lifecycle.value} == "")--><!--#if(${workspace.metadata.headerFooter.currentState.value} == "")--><hr /><!--#end--><!--#end--></div>
<!--#if(${workspace.metadata.headerFooter.currentState.value} != "")-->
<div id="itemdetails-state" class="workspacerow"><span class="rowtitle dysplayonly">${workspace.metadata.headerFooter.currentState.title}</span> <span class="rowtext nowrap">${workspace.metadata.headerFooter.currentState.value}</span> <!--#if(${workspace.metadata.lifecycle.lifecycle.value} != "")--> <!--#end--></div>
<!--#end--><!--#if(${workspace.metadata.lifecycle.workspaceType.value} == "6")--><!--#if(${workspace.metadata.lifecycle.lifecycle.value} != "")-->
<div id="itemdetails-lifecycle" class="workspacerow"><span class="rowtitle dysplayonly">${workspace.metadata.lifecycle.lifecycle.title}</span> <span class="rowtext nowrap dysplayonly">${workspace.metadata.lifecycle.lifecycle.value}</span> <span class="rowtitle dysplayonly">${workspace.metadata.lifecycle.revisionLabel.value}</span> <span class="rowtext nowrap dysplayonly"> ${workspace.metadata.lifecycle.lifecycle.value} ${workspace.metadata.lifecycle.versionNumber.value} - ${workspace.metadata.lifecycle.versionTimestamp.value} </span></div>
</div>
</td>
</tr>
</thead>
<tbody>
<tr>
<td>Insert content here...</td>
</tr>
</tbody>
<tfoot>
<tr>
<td>
<div class="print_footer">
<table style="width: 100%;" border="0"><colgroup><col width="80%" /><col width="20%" /></colgroup>
<tbody>
<tr>
<td valign="top">
<script type="text/javascript">// <![CDATA[
var d = new Date()
document.write(d.getHours())
document.write(".")
document.write(d.getMinutes() + 1)
document.write(".")
document.write(d.getSeconds())
// ]]></script>
</td>
<td align="right">${workspace.metadata.headerFooter.imageFooter.value}</td>
</tr>
</tbody>
</table>
</div>
</td>
</tr>
</tfoot>
</table>
</div>
::end of code::
Joseph Piggee
Fusion 360 Administrator
TPI Composites
jpiggee@tpicomposites.com
jpiggee
in reply to: jpiggee
Ekkk... Hold on, I'll clean it up and have something better in a few hours 🙂
Joseph Piggee
TPI Composites
jpiggee
Now with Date and Time!
**Note** Time is in 24hour clock format.
/* Start of Code */
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
<head>
</head>
<body>
<thead>
<tr>
<td>
<span class="open-change-indicator">${workspace.metadata.itemDescriptor.workingVersion.value}
</span><!--#end--></div>
<hr><!--#end--><!--#if(${workspace.metadata.lifecycle.lifecycle.value} == "")--><!--#if(${workspace.metadata.headerFooter.currentState.value} == "")-->
<hr><!--#end--><!--#end--> </div>
<!--#if(${workspace.metadata.lifecycle.lifecycle.value} != "")--><!--#end--></div>
</div>
</td>
</tr>
</thead>
<tbody>
<tr>
</tr>
</tbody>
<tfoot><tr>
<td>
<colgroup><col width="80%"><col width="20%"></colgroup><tbody>
<tr>
<td style="vertical-align: top; width: 227px;">Printed
Date:<br>
var d = new Date()
var weekday=new Array("Sunday","Monday","Tuesday","Wednesday","Thursday","Friday","Saturday")
var monthname=new Array("Jan","Feb","Mar","Apr","May","Jun","Jul","Aug","Sep","Oct","Nov","Dec")
document.write(weekday[d.getDay()] + " ")
document.write(d.getDate() + ". ")
document.write(monthname[d.getMonth()] + " ")
document.write(d.getFullYear())
</script>
</td>
<td style="width: 227px;" valign="top">Printed
Time:<br>
var d = new Date()
document.write(".")
document.write(".")
</script>
</td>
</tr>
</tbody>
</table>
</div>
</td>
</tr>
</tfoot>
</table>
</div>
</body>
</html>
/* End of Code */
Joseph Piggee
TPI Composites
Tags (1)
