Is there any way to specify the row id within a grid? It seems to generate automatically and cant be edited.
David.
Solved by broepke. Go to Solution.
Hi there,
The Row ID generated is actually a unique ID across all grids for the workspace (not all workspaces... just the one you're in.) This allows you to identify the row by ID via scripting and other things that need to reference a static ID. While it looks like it's might be useful to renumber those or whatever, noting that they're across the workspace might help understand why they are what they are.
If you want something that's more like 1,2,3, you can create a custom field for that.
Once you create a custom field can we make it an auto number? that gives the sequence upon row creation?
thanks.
