Our company receives quotes in multiple currencies from an array of suppliers. Is there a way to add the unit cost in the quoted, foreign currency? Is there a way to link to quoted currency to the current exchange rate in USD?
Thank you,
Darryl
Darryl - I'm not sure, but will look into this for you. In the meantime maybe someone else will chime in with an idea.
Michelle
Hi Darryl,
As for currency conversion, although this is would be quite the undertaking, I would suggest reading into Google’s API interface for currency conversion, which can then be added into a computed field and be able to do the conversions.
As for currency types within the system; this can be completed with a simple float and pick list scenario or for a more simplistic way, one could simply use a single line text field.
