Is anyone having isssue with My Recently View Items? For some reason this view will not refresh/update. It just shows items that I viewed in April of last year. Is there a setting I need to modify?
Thank You.
Solved by TLopez0. Go to Solution.
Solved by broepke. Go to Solution.
I had noticed this to and I just checked again and it seems fine. Can you take another look and see if it's still not working?
Thanks - I noticed something after I posted with mine
1. If I navigate to the item with the workspace browser (main menu > workspace > select an item from the list) it works
2. When I navigated to one via a relationship (linking pick list, associated workflow items, BOM, etc...) it didn't work.
Let me pass this on and we'll see if we can get this logged with Development.
Thx!
Got it - I checked with Michelle Stone and this was already logged. It's currently being worked on...
Why does this have to wait untilt the next PLM release? That is a month away.
What is the root cause? Why does it affect some users but not others?
Robb
This issue has been address with the May release. Let us know if you see otherwise.
It doesn't appear to be fixed for me either. See attached image. I haven't looked at the items highlighted in red in months.
