Fusion Manage Forum
Welcome to Autodesk’s Fusion Manage (formerly Fusion 360 Manage) Forum. Share your knowledge, ask questions, and explore popular Fusion Manage topics.
Error when adding multiplelines to grid at once
4 REPLIES 4
dkeeley
387 Views, 4 Replies
I am having a problem when trying to add multiple lines to a grid at once. The grid line contains filtered picklists. If I try to add one line at a time then everything works fine. But when I try to add multiple lines then only the first line contains the drop-down menus for the picklists.
Also, anoth thing I've noticed is that the picklists appear very small. Should these not be sized according to the size you've entered in the item details for that particular field?
See attacahed images.
I'm experiencing this error in all browsers: IE, FF, Chrome, Safari.
David.
Tags (2)
4 REPLIES 4
michelle.stone
in reply to: dkeeley
David - the second bit is a known issue and being worked.
I did confirm your first issue as well (see attachment) - like you said, one row works fine, but the multiple ones don't give the drop down.  Off to report this - thanks for letting us know.
Michelle
Michelle Stone
Technical Marketing, PDM & PLM
dkeeley
in reply to: michelle.stone
Thanks for the quick reply Michelle.
uffe.bak
Hi David
To your second point - field seems to show very narrow compared to set length value.
I believe this to be caused by a current issue where the setting is actually in pixels and not characters as stated in the help. Try increase the value to 80 and see if it helps. Maybe Michelle or John can confirm the issue?
Best regards
Uffe Bak
dkeeley
Thanks Uffe. That works a treat.
