Fusion Manage Forum
Welcome to Autodesk’s Fusion Manage (formerly Fusion 360 Manage) Forum. Share your knowledge, ask questions, and explore popular Fusion Manage topics.
Conditional Scripting checks on BOM fields
4 REPLIES 4
scottmoyse
1042 Views, 4 Replies
Can I access the BOM fields and perform conditional checks on them?
For example; above, I would like to stop a transition to released if these values haven't been filled out. I think you are going to tell me these checks should occur on a Revisioning Workspace Item? However, I want to see these values/checkboxes summarised in the BOM like this if possible. Otherwise the users will be jumping back and forth to find the information.
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
4 REPLIES 4
jpiggee
in reply to: scottmoyse
Scott,
Your concern has been addressed and is in the works, We hope to see this released soon.
As always thank-you for your continual input on the PLM product functionality.
Joseph Piggee
Fusion 360 Administrator
TPI Composites
jpiggee@tpicomposites.com
scottmoyse
in reply to: jpiggee
ok cool cheers
Scott Moyse
punisher
Was really hoping for some scripting love here. Thought it would help my current puzzle.
John Evans
Autodesk Certified Professional
http://designandmotion.net
jpiggee
in reply to: punisher
Scott,
This is a bit late but I'm trying to close the loop on some of these scripting items.
Yes you can write a condition script for checking BOM items:
BOM features supported:
item.boms -- A list of boms
item.boms.addRelated({ RELATED: target, QUANTITY: decimal, CUSTOM_FIELDS: [key,value], ITEM_NUMBER: int, QUOTE: item}) – Adds item to bom list
item.boms.addRelated(target,  quantity, fields[],lineNumber, quote) – Adds relationship to list
fields is optional
lineNumber is optional, if omitted then autonumbering should be used
quote is optional
item.boms[i] has the following properties:
  item.boms[i].id – DMS ID of target item
  item.boms[i].descriptor – Descriptor of target item
  item.boms[i].item – Target item
  item.boms[i].item.FIELD – Field on target item
  item.boms[i].lineNumber – The bom items line number (may not be needed, maybe the same as the index)
  item.boms[i].fields – access to bom custom fields
  item.boms[i].fields.FIELD – Field in the custom bom fields
  item.boms[i].qty – Quanity
  item.boms[i].quote - access to the line items quote
item.boms[i].setQuote(quoteItem) – Sets the default quote
item.boms[i].remove() – Removes relationship i from the list
Joseph Piggee
TPI Composites
