Hi there,
1. I made a test WS where I imported some data connected to a field with predefined names.
2. I made changes to the picklist, order and names
3. The data is now corrupt as what I think the picklist is based on the index and not the content
For example, the picklist used to be:
And I changed to:
In every item in the name field everything that used to be Jonas, ended up being Daniel. But only the data inside of the item. The description is still the same as the original.
Known problem?
Kind regards,
Jonas
Hi Jonas,
Have you considered creating a workspace picklist? In this case, the data will come from a workspace and not from a pre-defined list of values.
Jonas,
This is the way the software is designed. We save the Index so you can change the values without affecting the data that's saved. For example - Let's say today your pick list is
And later you decide you want to carry more car manufactures, you can insert the name / edit them in order to show this.
You can do this, and edit the values without breaking the data.
There is however a pick list type that can keep the retained Value so even if you change the pick list, you can make sure your item will keep the old value until you edit it.
Yes, I have. Just trying to miminize the number of WS.
Kind regards,
Jonas
