I am having problem with creating CASE statements in calculated fields. I am getting continuous server error messages.
David.
Solved by nguyentru. Go to Solution.
Hi David,
We understand the issue, and we are in the process of fixing this bug. It should be release soon.
In the mean time you will need to inser Else statement into your case statement have the computed field work.
For Example:
CASE
WHEN(TYPE=4) and (RATE is not null)
WHEN(TYPE=1) and (COST is not NULL)
ELSE 0
END
THANKS,
Trung
