Hi all,
I post here because I didn't find a dedicated group.
Autodesk 360 under WIndows 8 64bit cause explorer app to hang every few minutes.
The component that cause the hang is QtCore_Ad_SyncNs_4.dll also with the Live Update 1 installed.
Removing "Autodesk 360" from "Add/Remove program" also remove the problem.
The administrators could move this topic where they think is more appropriate.
Thank you.
Solved by michelle.stone. Go to Solution.
The Community group for Autodesk 360 is actually on a different site, so I can't move this but you can get to it here: http://feedback.autodesk.com/cloudservices/products/cloudservices_project_nitrous
I did a quick search and found this thread: Sync Error icon in Windows system tray. If that doesn't help, you'll at least be in the right spot to report the issue.
Hope that helps!
Michelle
Thank you Michelle,
that's why I could not find it... sorry
Thanks again.
