Fusion Manage Forum
Welcome to Autodesk’s Fusion Manage (formerly Fusion 360 Manage) Forum. Share your knowledge, ask questions, and explore popular Fusion Manage topics.
Autodesk Desktop Companion aka Autodesk 360
2 REPLIES 2
energymech
744 Views, 2 Replies
Hi all,
I post here because I didn't find a dedicated group.Smiley Embarassed
Autodesk 360 under WIndows 8 64bit cause explorer app to hang every few minutes.
The component that cause the hang is QtCore_Ad_SyncNs_4.dll also with the Live Update 1 installed.
Removing "Autodesk 360" from "Add/Remove program" also remove the problem.
The administrators could move this topic where they think is more appropriate.
Thank you.
2 REPLIES 2
michelle.stone
in reply to: energymech
The Community group for Autodesk 360 is actually on a different site, so I can't move this but you can get to it here: http://feedback.autodesk.com/cloudservices/products/cloudservices_project_nitrous
I did a quick search and found this thread: Sync Error icon in Windows system tray.  If that doesn't help, you'll at least be in the right spot to report the issue.
Hope that helps!
Michelle
Michelle Stone
Technical Marketing, PDM & PLM
energymech
in reply to: michelle.stone
Thank you Michelle,
that's why I could not find it... sorry Smiley Embarassed
Thanks again.
