A microphone shouldn't need drivers - just plug it into the Mic input on your sound card. All the settings should be in the drivers for the card.
Which sound card do you have?
What are you trying to use the mic with? Sound Recorder? VOIP app?
Try the following solutions:
Make sure that the microphone or headset is connected correctly to your computer.
Make sure that the microphone is positioned correctly.
Increase the volume of your microphone. Here's how to do this in Windows 10: Select Start, then select Settings > System > Sound
Will
What's there to update? There's not much to it and it's not an Autodesk issue.
