ObjectARX
warning C4700: uninitialized local variable 'pMyObject' used
5 REPLIES 5
944 Views, 5 Replies
It is correct?:
double radius; radius = 55.78; AcGePoint3d centerPt(0.0, 0.0, 0.0); AcDbCircle* pCircle = new AcDbCircle(centerPt,AcGeVector3d::kZAxis,radius); ACX_SetProp* pMyObject; pMyObject->setColor(pCircle, 2);
My CLASS:
class ACX_SetProp : public CObject
private:
AcDbEntity myObj;
public:
ACX_SetProp(); // konstruktor
~ACX_SetProp(); // destruktor
// color object
void setColor(AcDbEntity* pObject, short myColorIndex)
_color = myColorIndex;
AcCmColor cColor;
cColor.setColorIndex(myColorIndex);
pObject->setColor(cColor);
pObject->close();
protected:
int _color;
because I have an error message:
When run AutoCAD, then crash program.
I greet
5 REPLIES 5
owenwengerd
pMyObject is not initialized. Did you intend to create an ACX_SetProp object on the stack, perhaps? If not, you need to initialize pMyObject to point to an ACX_SetProp object before you use it.
Owen Wengerd
ManuSoft
in reply to: owenwengerd
Hi Owen,
thank you for your advice 🙂
I've rebuilt my class (mytest.h):
//**  My Class **//
class C_ACX_SetProp : public CObject
public:
	C_ACX_SetProp();
	~C_ACX_SetProp();
	short myColorIndex() const;
	static void setColorObj(AcDbEntity* pObject, short myColorIndex);
	static void setRGBColor(AcDbEntity* pObject, Adesk::UInt8 red, Adesk::UInt8 green, Adesk::UInt8 blue);
	static void setLineWeight(AcDbEntity* pObject, AcDb::LineWeight myLineWeight);
	static void setLayer(AcDbEntity* pObject, CString myLayer);
	static void setLineType(AcDbEntity* pObject, CString myLayer);
	static void setLineTypeScale(AcDbEntity* pObject, double myScale);
	static void setVisibility(AcDbEntity* pObject, AcDb::Visibility myVisibility);
	static void setTransparency(AcDbEntity* pObject, Adesk::UInt8 alphaPercent);
 and now method (mytest.cpp):
C_ACX_SetProp::C_ACX_SetProp(){}
C_ACX_SetProp::~C_ACX_SetProp(){}
void C_ACX_SetProp::setColorObj(AcDbEntity* pObject, short myColorIndex)
		AcCmColor cColor;
		pObject->close();
void C_ACX_SetProp::setRGBColor(AcDbEntity* pObject, Adesk::UInt8 red, Adesk::UInt8 green, Adesk::UInt8 blue)
		AcCmColor cColor;
		cColor.setRGB(red, green, blue);
		pObject->setColor(cColor, 1);
		pObject->close();
void C_ACX_SetProp::setLineWeight(AcDbEntity* pObject, AcDb::LineWeight myLineWeight)
		pObject->setLineWeight(myLineWeight, true);
		pObject->close();
void C_ACX_SetProp::setLayer(AcDbEntity* pObject, CString myLayer)
		pObject->setLayer(myLayer, 1, false);
		pObject->close();
void C_ACX_SetProp::setLineType(AcDbEntity* pObject, CString myLayer)
		pObject->setLinetype(myLayer, 1);
		pObject->close();
void C_ACX_SetProp::setLineTypeScale(AcDbEntity* pObject, double myScale)
		pObject->setLinetypeScale(myScale, 1);
		pObject->close();
void C_ACX_SetProp::setVisibility(AcDbEntity* pObject, AcDb::Visibility myVisibility)
		pObject->setVisibility(myVisibility, 1);
		pObject->close();
void C_ACX_SetProp::setTransparency(AcDbEntity* pObject, Adesk::UInt8 alphaPercent)
		AcCmTransparency trans;
		trans.setAlpha(alphaPercent);
		Acad::ErrorStatus es;
		es = pObject->setTransparency(trans, 1);
		if (es == Acad::eOk) {
			acutPrintf(_T("\nOK!"));
			pObject->close();
		} else {
			acutPrintf(_T("\nNot OK!"));
			pObject->close();
and finally (mytest.cpp)::
void goTest()
	C_ACX_SetProp* pMyObject;
	ads_name en;
	ads_point pt;
	AcDbObject* pObj;
	AcDbEntity* pEnt;
	if (acedEntSel(_T("\nSelect an entity: "), en, pt) == RTNORM) {
		AcDbObjectId eId = AcDbObjectId::kNull;
		acdbGetObjectId(eId, en);
		if (Acad::eOk == acdbOpenObject(pObj, eId, AcDb::kForWrite))
			pMyObject->setColorObj(pEnt, 2);
pMyObject->setLineWeight(pEnt, AcDb::kLnWt120);
pMyObject->setLineTypeScale(pEnt, 4.5); acutPrintf(_T("(%s)\n"), pEnt->isA()->name()); pEnt->close(); pObj->close(); } } }
No error, no crash. But this code was written correctly?
I greet,
Zbyszek
owenwengerd
Your code is still declaring pMyObject, but never initializing it. The only difference is no more crash because your calls to static members do not use the uninitialized pointer.
Owen Wengerd
ManuSoft
"Your code is still declaring pMyObject, but never initializing it. The only difference is no more crash because your calls to static members do not use the uninitialized pointer."
hmmm... 😞
what I shoud to change (.h)?
public:
C_ACX_SetProp();
~C_ACX_SetProp();
 (.cpp):
		AcCmColor cColor;
		pObject->close();
 it is wrong here... as will properly?
I want to write class to change possible properties selected object.
Checking possibilities I  had not written yet eg. exist Layer.
I greet,
Zbyszek
owenwengerd
It's not clear what you are trying to do, but it seems you are trying to write ObjectARX code without a fundamental understanding of C++. You may get more help if you post on a generic C++ forum and explain that you are learning. In any case, I think you must learn to walk before you ask how to run.
Owen Wengerd
ManuSoft
”Boost
