Dear Bernd,
You can use AcDb3dSolid::booleanOper to do this:
virtual Acad::ErrorStatus booleanOper(AcDb::BoolOperType operation,
AcDb3dSolid* pSolid);
operation Input type of Boolean operation
pSolid Input pointer to other solid with which to carry out the Boolean
operation
Performs Boolean operation between this solid and pSolid. Possible operation
types are:
AcDb::kBoolUnite
AcDb::kBoolIntersect
AcDb::kBoolSubtract
If the Boolean operation is successful, then pSolid's ACIS object is
deleted, Acad::eOk is returned, and the ACIS object's isNull() method will
return Adesk::kTrue.
If pSolid is NULL, then Acad::eInvalidInput is returned.
If the Boolean operation between the two solids fails, then the ACIS objects
of both solids are deleted and Acad::eGeneralModelingFailure is returned.
I hope this help!
Bill
"Bernd Willinger" wrote in message
news:83D50A2B2013817AE3F09704001B1C21@in.WebX.maYIadrTaRb...
> Hello there,
> in the ObjectArx Reference I found no "ARX-Way" (Memberfunctions of
> AcDb3dSolid or its base classes) similar to the 3DAcadcommands:
> unit,subtract and intersect. Of course I could use AcEdcommand but I want
to
> make it with ARX.
> thanks a lot
> Bernd
