Hello everyone!
Under what situation should I use the function "AcApDocManager::pushAcadResourceHandle" as well as its twin "AcApDocManager::popResourceHandle"?
Solved by owenwengerd. Go to Solution.
Use those functions to bracket any call to AfxSetResourceHandle(). Alternatively, use pushResourceHandle() to set the new resource handle while pushing the current handle.
I understand. Thanks to owenwengerd. Actually, these functions are seldom used. I toke note of them when I used AcApDocManager class to open dwg file from modeless dialog.
