Hi read for a long time on the help files. Just don't get a clue how to start, by any chance somebody got a sample code of it. Much appreciate.
Gat
Hi Gat,
Here is a simplest example using createRevolvedSolid.
It creates a cylinder by revolving a line about the Z axis. Hope this provides you a starting point.
AcGePoint3d sp(10.0, 0.0, 0.0); AcGePoint3d ep(10.0, 0.0, 10.0); AcDbLine *pRevEnt = new AcDbLine(sp, ep); Acad::ErrorStatus es; AcDb3dSolid* pShapeSld = new AcDb3dSolid (); AcDbRevolveOptions revolveOptions; revolveOptions.setDraftAngle(0.0); if((es = pShapeSld->createRevolvedSolid( pRevEnt, AcGePoint3d::kOrigin, AcGeVector3d::kZAxis, 6.28318530718, 0.0, revolveOptions )) != Acad::eOk) { acutPrintf(L"\nSolid creation failed...\n"); delete pShapeSld; return; } pShapeSld->setColorIndex(2); AcDbObjectId id; postToDb(pShapeSld, id); Here is the postToDb method : static Acad::ErrorStatus postToDb(AcDbEntity* ent, AcDbObjectId& objId) { Acad::ErrorStatus es; AcDbBlockTable* pBlockTable; AcDbBlockTableRecord* pSpaceRecord; if ((es = acdbHostApplicationServices()->workingDatabase()-> getSymbolTable(pBlockTable, AcDb::kForRead)) != Acad::eOk) { return es; } if ((es = pBlockTable->getAt(ACDB_MODEL_SPACE, pSpaceRecord, AcDb::kForWrite)) != Acad::eOk) { return es; } if ((es = pBlockTable->close()) != Acad::eOk) { return es; } if ((es = pSpaceRecord->appendAcDbEntity(objId, ent)) != Acad::eOk) { return es; } if ((es = pSpaceRecord->close()) != Acad::eOk) { return es; } return ent->close(); }
