Hi to all,
using Objectarx/C++, is it possible convert an Acad::ErrorStatus id to
a string ? There is a function that returns the id's relative string msg ?
Best Regards
Leonard
Solved by owenwengerd. Go to Solution.
There is no conversion to a message per se, but you can display the status name as a string by using acadErrorStatusText from acestext.h.
There's the acadErrorStatusText() function declared in acestext.h which takes an Acad::ErrorStatus value as an argument and returns a string which is the ErrorStatus enum name. It covers many of the common ErrorStatus values, but it does not cover all possible values.
