Guys,
i'm writing a bill of material program and have 3 attribute block symbols which are basiclly a simple close frame with some attributes inside these blocks can be freely inserted in dwg but also can be wrapped in a container block which also can be an xref. when the container is mirrored? the visibile attributes is unreadable.
i would like to to 'float' those symbols up to the current database (insert a new copy of it on a new layer
for visibily purposes and leave the nested\mirroed for billing)
i know how to get the nested AcDbBlockReference object but i need help in floating them up
(converting the position + scale + rotation)
Thanks in Advance
Solved by Moshe-A. Go to Solution.
Sorry, the explanation seems a little confusing.
Especially when you say " 'float' those symbols up to the current database (insert a new copy of it on a new layer for visibily purposes and leave the nested\mirroed for billing)"
If you can provide a simple buildable sample project demonstrating the issue that you are trying to solve, we can try and suggest a way to get to that functionality.
Balaji,
i gave this thought and took another approch
so thank you for trying to help.
moshe
