Rashidul,
I think the SetAcrxPtp was for older versions of AutoCAD. It's not required
here (maybe someone else knows more about this). Is Lib2010.arx the file
that you compiled? Which AutoCAD version was it compiled for. Which
compiler did you use (VS2005 or VS2008)? Judging by the name, it was
compiled for AutoCAD 2010. If this is the case, it will not load in any
version below 2010 (Map 2009).
Joe
wrote in message news:6233305@discussion.autodesk.com...
Hi Joe
Thanks for your quick reply.
But that line was also in our previous working version. But I don't know
more anything about that because
the developers are not here in my company now. I guess it may refer to any
dll/library, any idea?
I had tried by removing that line and then it compiled successfully. But
when I was trying to load the arx file in
Autocad (Map 3D 2009) then it fails with error stating.
Lib2010.arx is incompatible with this version of AutoCAD.
Thats why I guess that definition might be necessary...
Any clue in overall?
Thx
Rashidul
