ObjectARX
extract point data through traverseAllPointData by using spatial filtering.
2 REPLIES 2
dreamtnsrnd1
847 Views, 2 Replies
I want to extract point data through traverseAllPointData of AcDbPointCloudEx by defining a spatial filter. bellow is my codes.
in traverseAllPointData(...), if I set spatial filter to NULL, the process is success(err == eOK), if set as following code, then fail to callback process(err == eOutOfMemory).
what is the wrong? and how can correct use the spatial filter in  AcDbPointCloudEx::traverseAllPointData(...)?
class IPsAcDbPointCloudSpatialFilter : public IAcDbPointCloudSpatialFilter
public:
 IPsAcDbPointCloudSpatialFilter() {;}
 virtual ~IPsAcDbPointCloudSpatialFilter(){;}
 virtual FilterResult testCell(const AcGePoint3d& min, const AcGePoint3d& max) const { return IAcDbPointCloudSpatialFilter::FILTER_INSIDE; }
 virtual FilterResult testPoint(const AcGePoint3d& point) const { return IAcDbPointCloudSpatialFilter::FILTER_INSIDE; }
 virtual IAcDbPointCloudSpatialFilter* transformFilter(const AcGeMatrix3d& mat) const { return NULL; }
 virtual IAcDbPointCloudSpatialFilter* clone() const { return NULL; }
 virtual void freeObject() { ; }
AcDbPointCloudEx *pPCloudEntity = CPointShapeAPI::GetPointCloudExEntity(objID);
IPsAcPcPointProcessorEx pcProcessor;
IPsAcDbPointCloudSpatialFilter pcSpatialFilter;
pcSpatialFilter.testCell(min, max); // min, max are pre-calculated.
err = pPCloudEntity->traverseAllPointData((IAcDbPointCloudPointProcessor*)&pcProcessor, (IAcDbPointCloudSpatialFilter*)&pcSpatialFilter, IAcDbPointCloudDataBuffer::DataType::kIntensity, 100);
Regards!
Edgar Lee.
Edgar Lee
2 REPLIES 2
kubitTilo
in reply to: dreamtnsrnd1
Edgar,
you really need to fully implement the spatial filter interface, particularly
    virtual IAcDbPointCloudSpatialFilter* transformFilter(const AcGeMatrix3d& mat) const = 0;
    virtual IAcDbPointCloudSpatialFilter* clone() const = 0;
    virtual void freeObject() = 0;
Hope this helps.
Are you guys at PointShape migrating to AutoCAD 2015, huh? Maybe we can share some experiences Smiley Wink
Tilo Pfliegner
dreamtnsrnd1
in reply to: kubitTilo
Hi Tilo,
Thanks for your advice, it's helpfull to resolve this problem.
I have successfully completed the point query processor by implementing the spatial filtering class.
I feel the data query(extracting) performance is fine.
And, as you said, I'm a member of pointshape.
I also hope to sharing any experiences each other.
best regards!
Edgar Lee.
e1seop@gmail.com
Edgar Lee
”Boost
